Fur Face
Just found this if you wanted to try this formula. Like Mr. Gillespie had mentioned the OPT would still be under the voltage it would normally be taking using your 125v wall socket.
Turns Ratio = V in (to the primary) / V out ( measured in the secondary) e.g. if we apply 5 Volts AC and we measure 0.21 Volts AC to the secondary the Turns Ratio of the transformer is : 5 / 0.21 = 23.8 That means a turns ratio 24:1
Knowing the Turns Ratio we can calculate the impedance ratio of the unknown transformer and the impedance in a given load to the secondary. The impedance Ratio is the square of the turns ratio:
24 X 24 = 576 that means an impedance ratio 576:1
So in a given load impedance of 8 ohms the transformer impedance is 8 X 576 = 4608 ohm ( it is about 4.5K)
