OnTheFritz
Would these be a good match or are the speakers not high end enough for this amp?
Amp specs
Power output: 200 watts per channel into 8Ω (stereo)
Frequency response: 5Hz to 100kHz
Total harmonic distortion: 0.002%
Damping factor: 100
Input sensitivity: 0.15mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 74dB (MC), 89dB (MM), 113dB (line)
Output: 150mV (line)
Dimensions: 420 x 150 x 420mm
Weight: 19.6kg
Amp specs
Damping factor: 100
Weight: 19.6kg
