If the Emit is a more advanced tweeter and better performing, (here comes my dark thought) I should replace the Walsh with it...if I didn't care about originality. Have we seen that done? Of course I wouldn't hack up the cab so as to not be able to put a Walsh in when I could afford it.
i'd be remiss if i didn't chime in and suggest that an emit in a IIa (while an interesting idea) would open a can of worms that may never yield satisfactory results, and may prove to be more trouble than its worth. deviations from stock undermine resale value as well.
I haven't learned how to do multiple quotes quite right...by Coastsider...and it is a damn fine speaker so my suggestion would be to just leave your IIa's as is until you can source a pair of working Walsh's instead of trying to emulate the effect of the Walsh's with EMIT's because they just won't provide what loquatious refers to as the "sparkle" and "spaciousness" and what I like to call "shimmer" that the Walsh's add to the mix.
.You both give excellent points against the "dark thought", things I hadn't quite thought of. I am no sound engineer, so altering the crossover beyond its factory parameters would be a guessing game for me. Plus, the price of the Emits is up there with the Walshes, so no benefit there. Sage advice there, guys.
I asked Patrick, the maker of those new Walsh tweeters on that bid site, about using my old ones for rebuild, and he said it's an option BUT to quote him,
"...but these tweeters are 35+ years old now and many loose the sound output level by up to 50% and if you had one out of the two do this, your speakers loose balance and that magical sound that the Walsh tweeters provide."
I would tend to spring for those new ones he makes (where else would you get new ones?) than use some originals, based on his info. I'm not super anal about having a "100 point" restoration, and would be fine with their being close in appearance to the originals, and sounding a lot better.
as long as we've got some other monitor IIa owners in the mix, id like to ask something.
on your IIa's, how much clearance do you have between the top of the walsh's center support tube and the underside of the wood top? (naturally, measured when both walsh and top are installed properly). i have fairly decent clearance with the fabric top, but my wood tops are only a hair's width away from physical contact with the support tube, which bugs me.
this is something i am curious about re: the "new" walshes, and why i'm overjoyed that coastsider will be evaluating some. i can think of no one better qualified to assess them.
probably better suited to one of the walsh threads, but i have many questions. how will they fit? are they the same height as originals? can you use the original mounting holes? how is the maker (i take it his name is patrick) attaching the center support tube to the magnet structure? gluing, or drilling and threading? if he's doing any machining, are any contaminants introduced to the delicate voice coil area? how is he attaching the aluminum cone to whats left of the titanium dome? is he addressing the natural corrosion that occurs over time with aluminum in contact with titanium? is the spider comparable to the "specially designed" spider of the original? he is currently playing with center tube height because he hasn't got the foam properly domed. is that issue going to be addressed? what foam is he using? etc, etc, ect.
if the answers are good, there is an improvement in sound, and life expectancy of the new drivers seems reasonable, i'll buy some. i'd keep my originals in a safe place though.
What midrange do I need to be looking for for my Monitor IIa? Are there other speakers that employed the same one? I see a listing on E*** for a bunch out of a Quantum that look the same. He is advertising "5 hole"...is that what I need? Thanks.
I have attached a pic of mine after installing one of the replacement woofers. The hole looks kinda rough; I think the original owner cut it up to fit some aftermarket woofers in there, and was wondering what it is supposed to look like.
oh, and the midrange is frequently mis-identified as being sourced from peerless. however, the evidence points to it actually being sourced from braun..
a while back, some 1.5" dome mids showed up on parts express as "factory buyouts" that looked just like the ones infinity used. the ad copy said they were made in germany, and alluded to their performance being "like" braun or ADS mids.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=279-104
No problem.
The camera flash makes the doping look weird but otherwise it shows the mounting that you requested. The edge of the frame is flush with the face of the cabinet.
