Monitoring SSD/HD with Smart Tools
devnull
AK Subscriber
I started buying SSDs back around 2010, and other than some 2.5" drives for a RAID10 array in a backup server (Seagate ST4000LM024-2AN17V in the table), that's all I have bought since.
Through those 16 years, I've had three drives fail, two Samsung 2280 NVMe drives, and a KingSpec 2242 NVMe. The KingSpec wasn't a surprise so much. They're not a tier 1 vendor, and are no where close to it. It was also installed in a very small enclosure (MSI Cubi 2) where it ran hot.
The two Samsung drives were in servers. Servers I built that had no RAID1 set up for the system drive. One I determined was failing before it actually did. I was analyzing the smart data on the drives in a server before I rebuilt it and realized it was on the verge of failing so I pulled it. The other Samsung failure was one that took the server down.
I decided to set up a logging system where I wrote a script that collects smart data and writes it to the logging system, then use rsyslog to transfer those logs to a server and analyze the information there. I'll be setting up a dashboard in a service called Grafana, but decided to create a script that does it on the cli first.
Now I build systems with RAID1 arrays on the system drives, and will buy used enterprise SSDs whenever that is a viable option. Presently the two servers I have running are set up that way.
I'll expand this to include smart data from my laptops and whatever else that has SSD storage. These are the drives installed in servers, a router and a firewall.
'POH' in the table is power-on-hours.
Code:
root@morrigan:~# disk-report.py /mnt/storage-logs/hosts
HOST       DEVICE       MODEL                    CUR(°C)  MIN/MAX    POH        USED%    SPARE%   HEALTH
anand      /dev/nvme0n1 Micron_3400_MTFDKBA512TF 38       35/39      1,984      5%       100%     OK
anand      /dev/nvme1n1 Micron_2400E_MTFDKBA512Q 40       38/42      326        0%       100%     OK
macha      /dev/sda     WDC  WDS500G1R0B-68A4Z0  44       42/45      21,672     N/A      N/A      OK
morrigan   /dev/sdb     MKNSSDRE2TB              38       35/40      515        N/A      N/A      OK
morrigan   /dev/sda     Samsung SSD 850 EVO 1TB  29       27/30      35,816     N/A      N/A      OK
morrigan   /dev/nvme1n1 SAMSUNG MZ1LB1T9HALS-000 41       39/42      1,141      0%       100%     OK
morrigan   /dev/nvme0n1 SAMSUNG MZ1LB1T9HALS-000 38       36/39      1,141      0%       100%     OK
msicubi    /dev/nvme0n1 Sabrent Rocket nano      50       45/50      35,499     2%       100%     OK
msicubi    /dev/sda     Samsung SSD 860 EVO 500G 38       35/39      60,662     N/A      N/A      OK
scathach   /dev/sdc     INTEL SSDSC2BB160G4T     33       33/35      63,758     N/A      N/A      OK
scathach   /dev/sdb     INTEL SSDSC2BB160G4T     34       34/36      63,754     N/A      N/A      OK
scathach   /dev/sda     ST4000LM024-2AN17V       31       31/33      2,674      N/A      N/A      OK
scathach   /dev/sdf     ST4000LM024-2AN17V       32       32/34      2,368      N/A      N/A      OK
scathach   /dev/sdd     ST4000LM024-2AN17V       31       30/32      2,425      N/A      N/A      OK
scathach   /dev/sde     ST4000LM024-2AN17V       33       32/34      2,404      N/A      N/A      OK
The fields in smart data are somewhat different between consumer drives and enterprise drives as well as differences between manufacturers, which is why some show 'N/A'.
The servers have reasonably good air circulation so I'm not too worried about them from a temperature standpoint. The only one that I'd like to reduce the temp on is the Sabrent 2242 NVMe drive in msicubi. It's not showing any errors at this point, but I recently installed a service that allows me to run LXC containers on it and that tends to increase write cycles. On enterprise drives, I'd not be worried, but they have much higher read/write ratings than consumer drives.
I'm building this in order to avoid those surprises you get when drives fail. If you don't pay any attention to it you'll never know they're going bad until it is too late.
Here's a few more fields added for monitoring the read/write volumes.
Code:
root@morrigan:/usr/local/bin# disk-report.py /mnt/storage-logs/hosts
HOST       DEVICE       MODEL                    CUR(°C)  MIN/MAX    POH        READ       WRITTEN    USED%    SPARE%   HEALTH
anand      /dev/nvme0n1 Micron_3400_MTFDKBA512TF 38       35/39      1,984      73.25 TB   17.94 TB   5%       100%     OK
anand      /dev/nvme1n1 Micron_2400E_MTFDKBA512Q 40       38/42      327        158.24 GB  200.32 GB  0%       100%     OK
macha      /dev/sda     WDC  WDS500G1R0B-68A4Z0  44       42/45      21,674     10.00 GB   672.00 GB  N/A      N/A      OK
morrigan   /dev/sdb     MKNSSDRE2TB              38       35/40      516        1.56 TB    1.94 TB    N/A      N/A      OK
morrigan   /dev/sda     Samsung SSD 850 EVO 1TB  29       27/30      35,817     N/A        28.25 TB   N/A      N/A      OK
morrigan   /dev/nvme1n1 SAMSUNG MZ1LB1T9HALS-000 41       39/42      1,142      5.54 TB    6.75 TB    0%       100%     OK
morrigan   /dev/nvme0n1 SAMSUNG MZ1LB1T9HALS-000 39       36/39      1,142      5.50 TB    6.70 TB    0%       100%     OK
msicubi    /dev/nvme0n1 Sabrent Rocket nano      50       45/50      35,500     648.14 GB  8.90 TB    2%       100%     OK
msicubi    /dev/sda     Samsung SSD 860 EVO 500G 38       35/39      60,663     N/A        868.35 GB  N/A      N/A      OK
scathach   /dev/sdc     INTEL SSDSC2BB160G4T     32       32/35      63,758     N/A        N/A        N/A      N/A      OK
scathach   /dev/sdb     INTEL SSDSC2BB160G4T     32       32/36      63,754     N/A        N/A        N/A      N/A      OK
scathach   /dev/sda     ST4000LM024-2AN17V       29       29/33      2,675      N/A        N/A        N/A      N/A      OK
scathach   /dev/sdf     ST4000LM024-2AN17V       29       29/34      2,368      N/A        N/A        N/A      N/A      OK
scathach   /dev/sdd     ST4000LM024-2AN17V       28       28/32      2,425      N/A        N/A        N/A      N/A      OK
scathach   /dev/sde     ST4000LM024-2AN17V       29       29/34      2,404      N/A        N/A        N/A      N/A      OK
For the last few that I support, they have Samsung PRO drives. I seem to recall the read/write being a major factor in longevity. Much higher rates than other drives available. They had the funds and I gave them the best that I could find at the time.
Definitely read/write ratings are very important factors. Heat is another. I concentrate on making sure I have proper cooling and heatsinks for drives now.
However, when building servers, I'd avoid using consumer drives, and have been doing that with the recent server rebuilds I'm doing for my home lab, although there are still a some consumer drives included, but not for system drives where the OS is installed. You can disable the sleep modes on consumer drives, but surplus enterprise drives have read/write ratings that far exceed what consumer drives can do. Those Samsung Pro drives are rated very well, but are at best about 40% of the enterprise drives I have. The enterprise drives also have PLP (power loss protection) allowing them to complete writes before they drop power.
The table I provided shows servers, one hijacked MSI Cubi 2 for some small LXC containers and a router where I have two consumer NVMe drives where the OS is installed. One is a standby but not in a RAID1 array. I found the kernel I compiled for that router didn't include the administration modules for RAID management, so I had to work around that. Those drives idle (not much write activity on a router) at 40-43C, which is a little warmer than I would like, but I'm not too worried about them. I'll add a fan if necessary.
Here's that router
I spent several hours over the last few days working with Claude Opus (Anthropic AI) on improving the monitoring service I set up a few months ago. I'm monitoring NVMe drives, SATA drives and a set of 4 HDDs in a ZFS striped mirror (functionally the same as a RAID10 array). These are all in servers and network equipment. I'll add the laptops and whatnot sometime soon.
There were some changes required to address the difference in smart data fields between the various types of storage.
I'm not done with this yet, but it's a work in progress and this provides some solid data on what is the state of the various drives I have installed.
The 'USED%' field in the second section of the report is the percentage of the TBW (TeraBytes Written) rating of the drive. DTBW (Daily TB Written) is another attribute used on enterprise drives that's probably a better gauge, but I'm no where daily rates so that really doesn't matter.
Code:
root@morrigan:~# disk-report.py -t
Report Generated: 2026-11-17 20:34:53 (Trends: ~24h baseline)
HOST       DEVICE       MODEL                  CUR(°C)  Δ24H     POH        WRITTEN    RATE/DAY      SPARE%   AGE    STATUS
macha      /dev/sda     WDC WDS500G1R0B-68A4Z0 26       +1°C     22,785     779.62 GB   1.24 GB/d    N/A      34m    OK
macha      /dev/sdb     Samsung SSD 850 EVO mS 25       +0°C     11,638      2.90 TB    1.24 GB/d    N/A      34m    OK
morrigan   /dev/nvme0n1 SAMSUNG MZ1LB1T9HALS-0 36       +1°C     2,733       8.68 TB   23.67 GB/d    100%     34m    OK
morrigan   /dev/nvme1n1 SAMSUNG MZ1LB1T9HALS-0 39       +1°C     2,733       8.73 TB   23.66 GB/d    100%     34m    OK
morrigan   /dev/sda     Samsung SSD 850 EVO 1T 27       +0°C     38,600     28.25 TB   0 B/d         N/A      34m    OK
morrigan   /dev/sdb     MKNSSDRE2TB            33       +0°C     1,232       1.95 TB   77 MB/d       N/A      34m    OK
msicubi    /dev/nvme0n1 Sabrent Rocket nano    32       +2°C     36,943      9.30 TB    1.28 GB/d    100%     34m    OK
scathach   /dev/sda     INTEL SSDSC2BB160G4T   25       +0°C     64,177     139.74 GB  750 MB/d      N/A      34m    OK
scathach   /dev/sdb     INTEL SSDSC2BB160G4T   25       +0°C     64,181     357.04 GB  750 MB/d      N/A      34m    OK
scathach   /dev/sdc     ST4000LM024-2AN17V     29       +0°C     2,850       8.38 TB   47 MB/d       N/A      34m    OK
scathach   /dev/sdd     ST4000LM024-2AN17V     32       +0°C     2,793       8.97 TB   46 MB/d       N/A      34m    OK
scathach   /dev/sde     ST4000LM024-2AN17V     32       +0°C     2,829       8.96 TB   47 MB/d       N/A      34m    OK
scathach   /dev/sdf     ST4000LM024-2AN17V     30       +0°C     3,100      13.25 TB   46 MB/d       N/A      34m    OK
setanta    /dev/nvme0n1 SAMSUNG MZVLB512HAJQ-0 27       +0°C     15,780     25.32 TB    4.14 GB/d    100%     34m    OK
setanta    /dev/nvme1n1 SAMSUNG MZVLB512HAJQ-0 26       +1°C     52,104     34.79 TB    4.14 GB/d    100%     34m    OK
setanta    /dev/sda     INTEL SSDSC2BB800G4T   17       +1°C     55,684      7.09 TB   0 B/d         N/A      34m    OK
Note: 26 duplicate records ignored; 3571 legacy-format records skipped
Report Generated: 2026-11-17 20:34:59
HOST       DEVICE       MODEL                    CUR(°C)  MIN/MAX    POH        READ       WRITTEN    USED%    SPARE%   AGE    HEALTH
macha      /dev/sda     WDC WDS500G1R0B-68A4Z0   26       24/27      22,785      1.01 TB   779.62 GB  0%       N/A      34m    OK
macha      /dev/sdb     Samsung SSD 850 EVO mSAT 25       24/26      11,638     N/A         2.90 TB   1%       N/A      34m    OK
morrigan   /dev/nvme0n1 SAMSUNG MZ1LB1T9HALS-000 36       35/37      2,733       5.68 TB    8.68 TB   0%       100%     34m    OK
morrigan   /dev/nvme1n1 SAMSUNG MZ1LB1T9HALS-000 39       38/39      2,733       5.72 TB    8.73 TB   0%       100%     34m    OK
morrigan   /dev/sda     Samsung SSD 850 EVO 1TB  27       26/27      38,600     N/A        28.25 TB   1%       N/A      34m    OK
morrigan   /dev/sdb     MKNSSDRE2TB              33       31/33      1,232       1.56 TB    1.95 TB   0%       N/A      34m    OK
msicubi    /dev/nvme0n1 Sabrent Rocket nano      32       29/41      36,943     721.18 GB   9.30 TB   2%       100%     34m    OK
scathach   /dev/sda     INTEL SSDSC2BB160G4T     25       25/26      64,177      3.57 TB   139.74 GB  0%       N/A      34m    OK
scathach   /dev/sdb     INTEL SSDSC2BB160G4T     25       25/25      64,181      2.80 TB   357.04 GB  0%       N/A      34m    OK
scathach   /dev/sdc     ST4000LM024-2AN17V       29       29/30      2,850      44.99 TB    8.38 TB   N/A      N/A      34m    OK
scathach   /dev/sdd     ST4000LM024-2AN17V       32       31/32      2,793      46.01 TB    8.97 TB   N/A      N/A      34m    OK
scathach   /dev/sde     ST4000LM024-2AN17V       32       31/32      2,829      48.22 TB    8.96 TB   N/A      N/A      34m    OK
scathach   /dev/sdf     ST4000LM024-2AN17V       30       29/31      3,100      50.56 TB   13.25 TB   N/A      N/A      34m    OK
setanta    /dev/nvme0n1 SAMSUNG MZVLB512HAJQ-000 27       26/28      15,780     26.89 TB   25.32 TB   2%       100%     34m    OK
setanta    /dev/nvme1n1 SAMSUNG MZVLB512HAJQ-000 26       25/26      52,104     44.64 TB   34.79 TB   3%       100%     34m    OK
setanta    /dev/sda     INTEL SSDSC2BB800G4T     17       16/19      55,684      6.03 TB    7.09 TB   0%       N/A      34m    OK
The four drives in the ZFS striped mirror array on scathach (Segate ST4000LM024-2AN17V drives) are showing big READ numbers, ranging from 45TB-50TB. I had them in another backup server that did not run for very long, and that's probably where the read numbers must have accrued. I'll be monitoring to see if that attribute continues to climb, although it seems like it's probably fine from what I can see now. Those drives only have in the range of 3K hours, which isn't much.
