QSilver
I have this little kit amplifier that I blew up some years ago and I've been trying to repair it. So far so good - I got the schematic out and found a lot of damamged or blown components which I have replaced. One of the 0.47R resistors had blown so I have replaced that, along with the outputs, drivers and capacitors and the two diodes - not the zener diode.
I used a DBT and got a bright bulb. Powered off and found a short in T6. I repalced this with a KSC1845 - same as T4 and powered back on. Now the bulb goes dim but I have about 33VDC at the speaker terminals and a lot of heat coming from R13 to the point it heats the surround components up after being on for 10 seconds or more. It doesn't burn up but it is close. Would the most likely cause be T3? I have not replaced that yet...
When the amp blew, it took out T8, T7, R19, melted R16 in half, and T4. I repalced T4 and T5 with KSA992 and KSC1845 to get a matching pair and replaced D1 and D2, D1 had shorted.
I then replaced R13, R14 and R15 and all the electrolytics except for the main filter caps as a precaution.
