Barncats
Has anyone tried capturing a spade between the two parts of the barrel on these adapters?
A search did not turn up this question, so I am posing it here.
I have a pair of JMReynaud Trentés with signal coming from a Luxman L-80V sold-state integrated amp. Right now I am using JMR speaker cable, biwired. This cable was designed by JMR to be the ideal match for these speakers. The conductor mass is skinny enough to go into the crappy spring connectors on the back of the Luxman.
However . . . I have a pair of Transparent Reference cables that I would like to try, but they are terminated with large spades. No problem at the JMR end, as the speakers have robust Bennic binding posts that accept large spades. But any of the stiff-gold-rod pin connectors I have seen are better suited to straight-in connection than trying to gently bend them (which I have tried to do in the past) that would be required in this installation.
These flex-tip Monster QuickLcks look as if they might do the trick, as long as I can fit a large spade into that opening between the front and back parts of the barrel. They are no longer in production but there seem to be some floating around on ebay, etc.
Will squeezing the spade between those two parts of the barrell ensure sufficient contact with the central conductor part of the adapter?
Among current offerings on-line I see a variety of flex-tip adapters for bananas but not anything for spades.
I should add that if the Transparent cables are an improvement, I will replace the spring connectors on the amp with real binding posts.
Any experience with these QucikLocks? Thoughts/suggestions?
Thanks
Thanks
