hifijohn
floor tom-starts at 70hz with a very strong 160hz peak nothing really above 900hz.there is a smalll 3by4 piece of cloth taped to the edge to damped some of the sound.
cow bell-very few harmonics,starts at 900hz, everything below I will ignore,its noise from my floor tom.
cymbal with roofing nails-stock cymbal which I drilled 10 holes and put roofing nails in them, the sound is a big improvement over the stock sound, as you can see it is very rich in harmonics.
snare-very strong 200hz with a few harmonics, nothing over 800hz I have a 6by6 peice of cloth taped on it to dampen out the sound, without it the snare has far too much bit to it.
kick drum-very strong 60hz,but not much lower than the floor tom,few harmonics and nothing over 330hz.a small piece of cloth taped to the beater side and the beater is wrapped in some felt.the drum is raw , usually drummers put pillows inside to dampen out the sound and give it more of a 'thud' type of sound.
http://imgur.com/Q6kMIRm
http://imgur.com/uPKA57c
http://imgur.com/tyMxU6S
http://imgur.com/4OQJTQs
http://i.imgur.com/m7220ZD.jpg
