Well, just had ANOTHER Reflektor-factory KT88 tube cause an amplifier failure.
VAC Auricle Musicblock amp (monoblock)... client replaced the original (Shuguang-made) KT88s with a new set of Gold Lion KT88s. Amp proceeded to blow the main power fuse. Upon testing (with the original tubes reinstalled- they tested fine), the amp will not bias up correctly on one output tube (acts like the cathode circuit is blown open). Amp's going back to Florida, to get brought back to life...
I talked to Kevin Hayes of VAC about it... he said, in his opinion, that the KT88 tubes from the Reflektor plant (Sovtek, EH, Gold Lion, Tung-Sol, etc.) were actually the least consistent, most problematic tubes he tests, in trials in which he determines what he wants to use in his amps. Surprisingly (at least superficially), he now uses a specially-selected Chinese tube (naturally, he didn't go into all the details- it's sort of a business secret) in the outputs of all his KT88-based amps. Less than a 1% overall failure rate, over the last 2.5 years of usage of these tubes.
It's sort of sad to see what was once the premiere Russian plant fall to this level of low quality. Kevin did mention that in his experience, the Winged-C tubes (coming from the ORIGINAL Svetlana plant- NOT what's called Svetlana now, which is from Reflektor) are usually fine... but, that he likes the sonic character of the Chinese tubes better. But, he was pretty firm in his recommendation to stay away from Reflektor-plant KT88s of any sort...
Regards,
Gordon.
Regards,
Gordon.
