andromediamn
Hello all,
Could you help with my transistor replacement questions?
The four transistors at TR505 through TR508 are 2SC828.
The four at TR105 trough TR108 are 2SC1328.
All the above are listed on the SU-8600 replacement parts list as using 2SC1328
My question is would you replace the two types listed above with 2SC1845 as is the usual substitute for those listed ?
Also, there are two 2SC828 at TR407/TR408 , these are for the thermal compensation. Would you change these with the 1845s too? One of these 2SC828 is shorted, but I could easily use one of the pulls from above, if replacing it with an 1845 is not good in this application.
Hope this makes sense, coffee is still brewing...
Thanks everyone for your help
