dogn4u
Sorry if this subject has been beaten to death. I picked up a Klipsch 10" sub in great shape for $50. The problem is that I have an Onkyo integrated amp (A-9010) with limited outputs. There is no dedicated sub output and only one set of stereo speaker terminals. For now, to test the sub, I have it connected to the RCA "line out" jacks on the amp. The sub works fine, but of course the volume control does not affect the "line out". The only way to use it is to adjust the subs volume every time I change the amps volume. Not a very practical solution. I thought about using the headphone jack with a Y-cable to go from 1/4" TRS (stereo) to two RCA male jacks. Trouble is, plugging in to the headphone jack cuts the signal to the speakers. Grr. At least I know the sub works and sounds great.
I guess one option would be a speaker output splitter box - the kind that maintains an 8 ohm signal to each set of speakers. But I was wondering - can I just run two speaker wires off each speaker terminal - one to the sub and one to the stereo speakers? I understand that this would amount to parallel wiring and would put a four ohm load on the amp, right? The Onkyo amp manual says a 4 ohm load is fine...but I can't find the resistance of the sub if I connect to it via the speaker inputs.
So if I wire it up in this manner, am I putting the amp in danger? How can I find the resistance of the sub when wiring speaker cables into it? Thanks a lot for any help or advice...
Btw - completely unrelated - just got back from a great week of riding the mountain roads of Eastern Washington and Oregon. Wonderful, relaxing time.
Rudi
Rudi
