Screen Resistor Mod layout
I can't draw using a computer for ****. Hopefully you'll get the Jist.
On the 400 you are going to just add a 100oHm resistor to the screen Power lead to the jumper between pins 1 and 7. Disconnect the Screen buss wire from pin 1. Then connect the wire FROM Pin 1 to the free end of the resistor. KEEP THE RESISTOR LEADS AS SHORT AS POSSIBLE. See Improved setup for 7868 below!
On the 500B/C and the 800 B/C Pins 4 & 8 line up across the tubes so FISHER made one Jumper buss wire instead of 4 different screen wires.
1.) Cut the Buss lead at Pin 4 on Tube V13 for 500C and V10 on the 800C (inboard most tube).
2.) Separate the tubes at pin 8 and pin 4 on each tube. You'll end up with a jumper on eeach tube from 4 to 8.
3.) Solder a 100oHm resistor to each jumper keeping the lead as short as possible.
4.) Cut a piece of wire long enough to reach across the tubes. Cut insulation @ 4 places to solder in the resistors.
5.) Solder Each resistor's remaining end to the buss wire. Solder the END of the BUSS WIRE to the wire you cut in Step 1. Insulate with heatshrink.
You should have something that looks like the bottom drawing in both cases. On the 7868 the jumpers will orient up and down.
PINS 1 & 7 are the 7868 SCREEN's. drawing has been revised to reflect the correction..
11-16-2014Revised to show 7W resistor 1.2K to 1.5K depending on model unit On 7868 it connects to the buss wire as above.
On 7591's There is an improved setup. Thanks to Dave Gillespie for the improvement.
NOTE: This also works for Sansui 1000A with a slight modification (pairs are physically separated so screen lead is bifucated at the 1st pair closest to the main Power supply caps). Other than that it's identical. On the Sansui disregard the #4 instruction below as it doesn't have the 7W resistor.
7591 ONLY IMPROVED SETUP
1.) disconnect the old buss wire from the tubes. cut and remove the buss wire from between the output tubes.
2.) run a new wire of sufficient length to daisy chain the tube sockets at pin 1.
3.) install a 100ohm resistor to each tube socket from pin 1 to pin 4. Pin 1 is not used and is not connected internally.
4.) connect flying end of the 7W resistor to one of the center tubes. PIN 1. It must be before the 100ohm resistors.
5.) Connect the new buss wire to each tube's pin 1 in turn. Solder all connections.
Larry
7868 ONLY IMPROVED SETUP (Similar to 7591 except for Pin #)
normally.
1.) Same
2.) Change to Pin 8
3.) resistor to pin 8 to pin 1. Pin 8 is NOT used normally
4.) Connect the 7W resistor to one of the center tube pin 8.
5.) Same except for pin 8.
