Mperron
Hello all! I have talked about this in another thread but it suggested I start a new one. I have a Motorola SK32W that I inherited when I purchased my house. It sat in the garage here in New England probably for 6 years or so until I moved it back in the house this summer. Not being up to speed yet on old audio equipment I plugged it in and it worked. Even the record player worked. I listened to it for a couple days and then it suddenly stopped. I started to investigate the problem and that is when I found this site. I located schematics and found the 3 amp slo blow fuse. jumped in a new one and of course it blew. I learned that all capacitors should be changed. So I did so. I replaced the can cap with the required elecrolytic caps and all the other "gum drop" ones. Jumped in a new fuse and it still blows as soon as I turn it on. I was told maybe the rectifier could be the culprit, so I removed it and it still blew the fuse. So now I guess I am looking for some more advice on what could be the issue. I don't have fancy test equipment but I do have a ohm meter. I have a basic understanding of schematics and my soldering is getting better!
I am going to post some pics of what I have so far.
Thanks in advance!
Thanks in advance!
