The mounting flange of the LE14H-3 is quite a bit thicker than the flange of the LE14H-1, so if those 1 1/2" bolts are stock for the 250ti, the replacements will need to be maybe 1/2" longer.
But the 10-32 part is probably the part larsne needed, being in Europe. Just try to find some 10-32 screws about 1/2" longer than he has and he should be good.
The problem is not finding screws of correct length and width, its the TPI(Threads per inch). In the US its generally more fine than standard European screws.
I've contacted Harman support and currently awaits reply.
Black bolts have been a pain to find.
