Always wanted to do astrophotography but the expense the the time and effort it was just too much. Same with a 8" Celestron with a equatorial mount that even as a GoTo scope it was such a heavy PITA to haul around and set-up for me it wasn't worth it. Then the Seestar S50 comes out at a surprisingly low price for it's capabilities. It arrived this morning and after making sure it arrived in working condition went about setting it up
Downloaded the app to the phone turned on the scope. In about 10 seconds it said it was ready to connect. Yes it talks to you. Connection was quick and simple then immediately wanted to update the firmware. Once done it was time to take a look at the Sun. It's an overcast day so it wasn't going to be that great but was interested to see how it did with overcast skies. Once on the deck selected Solar System then sun. Asked if the filter was on then asked to find the sun so sent it on it's way. It failed. Was at the right height but looked to be an hour behind. Slewed the scope over and after some searching got it in view hit auto focus. Even with the cloud cover it worked. Took some photos which looked better than they should. Did this with the charge it came with and was ready to be recharged. Best thing is you can set it up go back in the house control from inside and watch the scope take and stack pictures on your laptop. I'll be able to see things better, farther away than even the 8" scope. People are doing wonerdful things with this 5lb wonder.
This is untouched straight from the scope. On a good day and stacking a few dozen shots it could come up with some really good stuff.
