Moving to Ireland from Canada
oldgruffy
Hi
I have an Akai AM 2450 amp, AT 2450 tuner and Technics SL 230 turntable
Will I be able to use them in Ireland where the voltage is 230v 50 Hz. Is there a switch inside that will change the voltage settings?
The turntable works in 50-60 Hz at 110 volts.
I found the circuit diagram for the amp and there seems to be a switch. Is that possible?
Thanks
Manoj
From your schematic, just a matter of changing the rating and position of a fuse.
I moved to the UK from Canada around the start of the century, and kept various pieces of gear. Any that isn't switchable or multivoltage I run through a step-down transformer.
Great, thanks Dave.
Guess I'd have to use a transformer for the turntable?
Would it be an issue if the voltage is 230 instead of 220?
Have a great day
Great, thanks Dave.
Have a great day
A transformer should work for the turntable -- assuming it isn't internally switchable or multivoltage; I haven't checked -- and 230 should be no problem.
I have a few piece's of equipment I brought in from the US. It all works no problem with a step-up transformer ( Get a good meaty one ).......And............
Cead Mile Failte! :beerchug:
Ist takes more than a voltage change for most turntables when going from 60 to 50 cycles. Usually involves a pulley change to get the platter to spin at the correct speed.
Aren't Technics turntables of that era all electronic speed control and DC motors, rather than AC synchronous motors that are dependent on line frequency?
