Folks, I am the new proud owner of a McIntosh MR 80 Tuner that I scored on Ebay, The description indicated that three of the four touch keys were not working. I figured I could fix it and gave the seller a low ball offer which he (to my surprise) accepted. I received it last week and I have looked it over. It is beautiful! Not a scratch or blemish. I got to work studying the schematics. I noticed that this unit uses the same cap touch system that was used on many kitchen microwaves back in the 70's and 80's. It is an obsolete TI part called the TMS1976, Touch Controller. It is so obsolete, that I can't find a data sheet for it. I found a website that has a used solder pull part and they want $12 for it. However, the shipping was $45!!!!!!!!!! I said boo hiss on that. I can pull the MR 80 apart and try adjusting the sensitivity to see if this get the faulty 3 input switches to work, but this requires pulling the panel off which I have never done.
If this simple fix does not remedy this problem, I can build an emulator using a RP Pico and a level shifter mounted on a daughter board that pops onto the 18 pin DIP socket.
Is there anyone out here that has run into this issue before? If so, I would love to find out how you resolved it.
