pgena
Member
My Mr77 sounds fine, but at around 10 minutes after power-up, the right channel gives way completely to white noise. Though the station is strong (6+), a quick turn of the Stereo Filter switch to 1 returns the sound on the right and the sound is clear for the duration. If I switch the filter back out, the right channel is clear for about a minute until it's lost again. The Filter makes a popping sound with each turn. When I change the mode to Mono, the right channel is still bad.
Having heard the tantalum horror stories, I switched them out on the MPX and output amplifier boards, even the "ghost" C8 tantalum (which, as noted in earlier threads, doesn't exist on the schematic or on the image of the printed circuit board in the MR77 service manual - for the batch in which my serial number lies).
When I powered up, the C8 replacement literally blew up! I'm guessing that the polarity might have been incorrect - I had the negative going to ground. That may have been the cause, but it was a crap shoot without this "ghost" appearing on the schematic, as I couldn't decipher the polarity on the old blue tantalum. I cleaned up the mess and left C8 out of the circuit (again, in a previous thread some questioned its purpose anyway).
I powered up the unit again, and I must say that there was a noticeable improvement in sound, and I thought that this work may have eliminated the rt. channel noise issue. Alas, to my chagrin the noise returned after the ten-minute warmup, behaving the sam way. I would appreciate any thoughts or direction. Thanks!
