jdelange
Member
Recently I acquired a Pioneer CT-S810S 3 head cassette deck. After replacing the belts I made a recording on a TDK-SA90 with auto BLE without any Dolby. I must admit that I am quite impressed with the sound quality. There are more highs in the recording than I ever had on a cassette. Difference between source and recording is difficult to determine.
Then I put this tape in my Sony TC-229SD which is part of my 70's series Sony setup (TA-5650, ST-4950), and gone where the highs. It sounded muffled as I have grown accustomed to cassettes sounding. Now my question is: is this due to the old tech? Did old cassette decks just don't produce these highs? Or should this be fixable?
Before I took the Sony in operation I cleaned and demagnetized the heads.
Assuming this should be fixable or at least be improvable I was thinking of the following approach:
1. Perform checks and adjustments as per the service manual
2. Create an azimuth tape on the Pioneer (I will settle for that sound quality any day) using my Leader LAG-27 tone generator creating 6 kHz, 10 kHz and 15 kHz tones of 5 minutes at - 20dB.
3. Run the azimuth tape in the Sony TC-229SD and check the phases using my Tektronix 475 in normal and XY mode and see if the azimuth of the Sony can be improved (to match the Pioneer). Background: most of my tape collection is from the 70's-90's. Its pretty worn, both in quality and content. I plan to create new recordings on the 3-head Pioneer which I then would like to play on the Sony (and other cassette players). So the Pioneer is the starting point and reference.
4. So far, actions are easy. Next steps would be improve / repair the electronics of the Sony. Yet I do not know if something is wrong. It's playing, so what to look for and how?
Recapping comes to mind, but I doubt if that's going to improve the highs? It's good to note that the highs are lost in the playback part as I did not record on it and Dolby is off.
So what are your experiences with high frequencies on 2-head 70's decks and did you have any luck in improving dull, muffled decks?
As a side note: it is interesting to see that there are many video's of people adjusting the azimuth of their recorders, but I have yet to see a video where the before and after results are demonstrated. I am guessing something like that could be done with REW whereby a test tape is recorded (on the Pioneer) and then played back on the Sony and checked with REW. I haven't checked this out yet.
