Mullard 12ax7 ?
EVGuy
I was digging through a box of old tubes I've had for a while and came across these two. Can anyone identify the date codes for me and which should be a better fit in my BBX II?
Mullard 12ax7 long plate, square getter supported on two posts, copper grid posts- Made in Great Britain MC1 B6J
Mullard 7025 long plate, halo getter, copper grid posts- Made in Great Britain with Mullard shield, 1022? running vertically and a very faint B with other markings that are gone across the bottom.
I used to find the square getter Mullards in old test equipment along with Mullard 12AU7's. The first time I sold them on the Bay all I knew was Mullards were good tubes. Then a bidder asked if they had square getters, they did. Figured if he's asking it must mean something so I added it to the description and boy did the bids take off. So the square getter is a valuable tube and a 7025 is always good. I would say late 50's early 60's for the square, 7025 no guess.
Did a little more digging and found a Hammond labeled Amperex made in Holland with the Heerlen code. I've been using an RCA black plate from 1958 in the BlueBerry which sounds great but thought maybe one of these would be a better choice. I'll try them out and just see which sounds best to me.
1022 is the code for IEC - they started distributing Mullard in the mid '60s. Too late for a long plate from Blackburn... but IEC relabeled many other tubes in later years.
You're right Tom, it's not a long plate. I mis-spoke. IEC made tubes would have the Mullard shield on them? Was the 7025 supposed to be a better tube for audio or just more rugged?
IEC may have labeled 7025 on a regular 12AX7 - wouldn't surprise me... but then Mullards are usually quiet, and 7025 is a low noise version of 12AX7.
