Amazon.com: ziaoou 1PCS Tube Amplifier Single-Ended 5K Single-Ended Output Transformer for 6P1 6P14 6P6 0-4-8 Ohm DIY Vacuum Tube Amplifier, black, 512852 : Industrial & Scientific
www.amazon.com
you can get those from several vendors but they all appear to be the same thing. I bought them from whoever had them listed for the least amount of money on that specific day. Usually not the ideal criteria for shopping hifi components but I was curious what the absolute cheapest thing I could find would do.
If you want a lot of words, here is my end result
I've made mention in a few other unrelated threads that I've been fooling with a single ended Magnavox amp, and promised I'd do a writeup once I was done. Well I am and this is that. First to set the stage, this amp came from here...
audiokarma.org
but 4.2 watts, flat within 0.5db from 30hz - 20khz and power bandwidth (half power) down to 23 hz. Better iron might get you flat down to 20hz but there isn't all that much happening between 20 and 30 and its going to need a fair bit more physical size to get there.
Can always throw one on and see how it compares to the original. Swap the second on and either leave it, or just make use of the amp while you have the failed original re-wound depending on those results.
