I think I understand the general design differences - Mullard has pentode input stage with LTP inverter. Williamson used triode input stage and split load inverter. My question is what are the sonic differences and which is your preference? From an experimental standpoint, is it fairly straightforward to swap between the two front-end circuit styles (prior to the output stage coupling caps) with the understanding that there could be gain differences and NFB adjustments needed?
