I have a pair of Luxman MB3045's mono-block amplifiers that could use new power supply caps.
I've been looking high and low for high voltage multi-section capacitors, not the twist-n-lock type, the kind held by a clamp.
220 uf @ 500 VDC (two in a pack)
47 uf @ 350 VDC (three in a pack)
47 uf @ 350 VDC (two in a pack)
Also working on an old Sansui SM-80 receiver with the same clamp-style arrangement
40 uf @ 350 VDC (two in a pack) 47uf would work
20 uf @ 350 VDC (four in a pack) 22uf would work
I found one value (50uf x 2) "Mojo" caps on Parts-Express. On backorder.
Are they any good?
Are they any good?
