It's not that I'm cheap. I'm just lazy
. I use a TV style rabbit ears for my FM tuner antenna. Actually, I tried a nicer antenna that I planned to install in my attic but it ended up having worse reception than my old rabbit ears.
The rabbit ears are mounted out of the way (somewhat hidden) in a corner. My question is could bass from my speakers be affecting its reception? I thought maybe the vibration would cause the distance from the corner to vibrate causing multipath interference. Is that a valid concern?
. I use a TV style rabbit ears for my FM tuner antenna. Actually, I tried a nicer antenna that I planned to install in my attic but it ended up having worse reception than my old rabbit ears.The rabbit ears are mounted out of the way (somewhat hidden) in a corner. My question is could bass from my speakers be affecting its reception? I thought maybe the vibration would cause the distance from the corner to vibrate causing multipath interference. Is that a valid concern?
