Hi there folks,
I am in the market for a push-pull valve amp for my main system and after quite a lot of reading, watching and budget consideration I have brought it down to a choice of two.
The Willsenton R8 and the Muzishare X7.
Both are excellent sounding/looking valve amps from the reviews but as yet I have not seen a direct comparison of the two and I'm having a hard time coming to a decision without actually being able to hear them first hand.
Pros and Cons.
The X7 has a phono stage. Though I find myself using vinyl less and less these days with most of my library in FLAC format or streamed from Tidal.
The R8 has a bias meter on the front, no VU meters. The X7 has two VU meters on the front that are used to bias?
The remotes for both seem solidly built though the R8's remote seems to have more functions.
Both look great, though the R8 in black is particularly appealing. The X7 has a slightly smaller footprint though about the same weight.
The R8 has a switch for changing the KT88's with EL34's. But I read that the X7 can also be fitted with EL34's if you adjust the bias to 33-35 instead of 50. Anyone know if that is correct?
I am planning to pair them with a set of Triangle Borea BR 03's for now. Though later I would like to try them with my old Epos ES14's.
Can anyone tell me how the X7's 12AX7 and 12AU7's compare to the R8's 6SL7's and 6SN7's?
My music tastes vary from Jazz to Thrash with a lot of Progressive Rock, occasional classical but very little in the way of Pop, Rap, Dub etc.
If anyone has experience with both and can lay out the differences I would much appreciate it.
Thanks
Pros and Cons.
Thanks
