Mx 112
micheld19
I have a problem with a power transistor NPN marked Q 202 (Mcintosh 132-516) on the diagram of the MX 112 (power supply). On this transistor is marked F 028 - S 1847 740 I didn't find the datasheet of this component. By which component then could I replace it
Thank you very much for your help
michel
Hmmm. I don't have a cross reference for 132-516. However, Q-202 in an MX-115 is 132-028, which is 2N3738 (TO-66). Also, NTE124.
Just a quick look at the schematics of the 112 and 115 shows that the voltages are the same so perhaps 2N3738 is it. Maybe. :D
Murray
MX112 service book is wrong, a 132-516 has never existed according to the McIntosh parts book, use the 132-028.
Good evening, After having repaired, with your assistance, the power supply of my MX 112, I check the tuner part. A thing intrigues me: what means LDR Network. Moreover, I must modify the de-emphasis to pass it to 50 microseconds. Is it correct if I replace resistors 122 and 123 of 150 K by 100 K (MPX section). Thank you still for your assistance
Michel
