MX-113 Front Panel Bezel
schwarcw
AK Subscriber
Greetings!
I have not been successful in locating a new or used front panel bezel for my newly restored MX-113. Yes, I have tried all the usual folks (Audio Classics, McIntosh, Terry Dewickt and Tom Manley)
I was hoping an AK member could take a hi rez photo (5 MB or so) of the bezel with the inside and outside dimensions. Post it in the thread or PM me for my email. I would like to make a glossy photo "bezel" and use some gummy glue to afix it to the front panel until I locate an actual bezel somewhere.
Any other ideas would be appreciated. Thanks!
Carl
Once you have the dimensions (which McIntosh might supply) you could have a plastics fabrication shop make one for you out of black Lucite or other plastic. Won't be cheap for a one-off, small machined piece. The places that make TT dustcovers would be a good place to start looking for a fabricator. Believe there is one that advertises at the bottom of each AK page. Good luck.
Mx113
I might be able to help. I was hoping someone who actually had an MX113 would take a dedicated close-up photo for you.
I'll go through my photos and see what I can come up with for you.
VintageMac
This is the best i could come up with. I don't have an MX113, so I can't supply a photo.
However, this is from the MX113 owner's manual.
You might take this to a sign maker who does vinyl and have them make it in black and gold. Then attach that to a piece of brass cut to the size of the bezel and you are good to go (until you can get one from McIntosh).
If you need a higher resolution image, contact me. The site "dumbed down" this image resolution.
VintageMac
I have an MX113 and I can try to get you the pic you need. If I'm correct, you just want the bezel surrounding the push buttons? Please PM me with your email.
VintageMac, this is very nice!
Newby, I'm sending you a PM. I have the dimensions around the buttons actually, I could use some help with the outside dimensions. Thanks everyone for your help!\\
regards,
Carl
Bally,
Do you have any record of who you talked to at Mac? A receipt or something?
Regards,
Carl
Newby (Tom) provided me with some exceptional photos. Here's kudos to Tom and his AK spirit to help other Forum members. Three cheers! Thanks a million!:banana:
Regards,
Carl
Newby (Tom) provided me with some exceptional photos. Here's kudos to Tom and his AK spirit to help other Forum members. Three cheers! Thanks a million!:banana: Regards, Carl
I have an old bezel laying around somewhere (MC2125). If you would like me to give you any dimensions with a caliper, let me know. Same for a C29 bezel.
Sure! I'd be interested in the dimesions. Tom gave me the demensions for the 113 he has that measure 4" X 1". Would there be a difference between units?
Regards,
Carl
I was thinking more accurate dimensions on thickness, width of the base and the silver line, etc. Isn't the cross-section a truncated isosceles triangle? The ones on MC2125 and MX117 are. While I did not lay them on top of one another, going from memory the bezel for the MX117 and MC2125 are the same.
OK............
C29 bezel:
0.164 thick (probably +/- 0.005 due to some glue still on the back).
0.055 is the width of the silver on the front edge.
0.120 thick inside the raised edge.
MC2125:
0.345 thick (with the same priviso as the C29).
0.055 width on the silver, so they match.
MX 113 Bezel -need one...
Hi,
How did the bezel search or replacement go? I'm in the same position, mine was lost in a move.
Any clue is helpful,
Jim
