fulcheryhue
Hello!! I recently acquired a MX113 for free and it's in pretty good playing condition for what I'm using it for (cosmetics condition not so much...), However there are a couple things that have been bothering me that I wanted to see if I could do anything about. I plan to take it for a complete service when I get the money, but as I'm a broke college student that isn't really feasible at the moment.... So I'm left to use my very limited knowledge and hopefully the advice of others to try and fix what I can on it.
The biggest issue imo is the treble adjuster, when at 12 o'clock it is incredibly muddy and you can hardly hear uppers, but when you turn it clockwise a very noticeable background fuzz shows up, and since I want the music to actually sound good I have to have the treble turned up at all times which of course causes the fuzz... From my research it might just need cleaned but since this is a pretty expensive unit I want to get advice before I do anything.
The other main issue is the RCA ports, mainly the phono (I'm really only using the phono currently so it could be all of them), if the plugs aren't in a very specific position there is a loud buzzing noise and cracking/popping, again I'm assuming they just need to be cleaned but I want to make sure. This could also be caused by my turntable (AR XA) which doesn't have a ground wire.
The only other big problem that isn't as important is just a constant general background noise, it's only really noticeable at louder volumes or when you are super close to the speaker so I'm not worried about that/it could be normal.
I haven't really noticed much else besides some minor things which are mostly cosmetic or just apart of normal cleaning. I'll list them out but it's not things I'm horribly worried about, as there isn't much I can do about it.
- The TAPE button is loose and you can just pull it out.
- The rust on the chrome chassis and the black metal.
- Bubbling and flaking on the front glass and letters.
- A bunch of dirt/dust between one of the component boxes and the front.
The previous owner told me that when he acquired it, it had suffered from water damage, but that he'd gotten it serviced and that most of the issues should have been fixed besides the AM tuner which is completely dead, which isn't really a problem for me as I doubt I would ever really use it. The water damage/normal aging has caused some rust and oxidization which I'm assuming might be the cause of the RCA noise.
If anyone has any suggestions to try and fix these issues I'd be incredibly thankful, this is kinda my first serious system and I really want to make it last. Also if there is any other information I can provide that would help I can provide it. I was told to get DeoxIT D5 by my uncle for some of the cleaning so I have that if it helps.
