Help! I have had an MX119 for about six years, and it has (and does) work wonderfully. My issue is that I recently upgraded my TV to a "Samsung UN46B8500 46-Inch 1080p 240 Hz LED HDTV". I have the new TV connected to the MX119 with component video (no HDMI output on the MX119). This has worked fine with my existing video inputs which are all connected to the MX119 with component cables also.
Recently, however, I went to access the Settings Menu on the MX119 and I could not get it to display on the new TV. I finally had to get a smaller TV and connect it to the MX119 by S-video. This worked OK, and I changed what I needed to. Still, I don't want to have a move a TV around every time I want to access the Settings Menu.
Moreover, I wanted to add a Wii to the system. The Wii only has composite video out. I ran this to one of the normal MX119 video in areas and carefully checked the settings. Again, I could not get any video from this set up on the main TV (or the smaller TV) through the MX119. Audio worked fine. I tried using the video upscaling option in the settings, and that did not help. I also connected the Wii to the smaller TV by composite video and it worked fine. I do not want to (and cannot) connect the Wii to my new big TV directly.
So, why would the new TV not recognize either the Settings Menu video feed or the Wii video signals but does see everything that is input through component video?
