xXSHADoW93Xx
I picked this up for $20 a few weeks back, in AS-IS condition.
Has a factory-installed Tenorel 2001 magnetic cartridge:
The motor was completely seized up, and when I tried to repair the motor, the motor literally fell apart, the connections crumbling. The idler wheel also had several notches.
Fortunately, I found a replacement idler wheel for only $10 and it's in excellent shape:
I also jerry-rigged a BSR turntable motor for the time being, so I can at least use it for 33 1/3 RPM, until I can find a proper replacement motor (Collaro 600 series or Magnavox Micromatic W700/W800 series motor)
Even though its jerry-rigged state limits it to being a 33 1/3 rpm only player (because the 45rpm step on the BSR motor actually gives the turntable the proper 33 1/3 RPM, while the other steps are unusable), the changer mechanism works fantastic, especially the auto-size detection!
