Djcoolray
Addicted Member
I look at it this way....
First the cost of replacement over a person getting up under the car fixing things and doing preventative maintenance. What’s the active ingredient in salt.....sodium, what neutralizes salt (sodium)....potassium citrate powder. Ever see those bottles that attach to the garden hose for fertilizer applications....exactly !!! Steam clean the underside then follow through with a rinse of potassium citrate using a bottle mixer for applying potassium to the sodium to neutralize the sodium. Then there is polyurethane sealers that can be sprayed under the car as a primer for rock-shield coating using a spray gun device hooked up to a rental air compressor. Like my uncle said, if your lazy and don’t do nothing....something is going to happen anyway that is beyond your control, then your going to play with hell catching up with the damage that time and the elements have reeked upon your car. In Germany I put my car up on the rack and steam cleaned it weekly. A person doesn’t have to look at the destruction caused by sodium as death of an auto by natural causes. Holes in a car can be patched using rivets and applying Duraglass over the top to strengthen and seal up the area. I’ve smeared Duraglass under the complete bottom and wheel wells of a car, then along with steam cleaning the bottom of the car regularly and then with potassium to kept the rust under control. Because doing that is cheaper than constantly replacing a used car every five years.
