jcolletteiii
Did anyone to the G terminal ground improvement as part of the Mcshane kits?
I did not.. what kind of improvement is it supposed to ad?
I did install a star topology in the grouding but did not bring the transformer grounds to that central point. The star and bussbar type schemas are most beneficial in the low signal circuits but I guess it could hurt on the transformers as well.
Steve
Not sure exactly, but I think the goal is for all DC to be grounded at the bus bar and all AC to be grounded to the chassis - minimizing hum maybe? This is the excerpt from the level II sheet from Jim on the topic:
"5. The last step is to improve the output transformer G terminal ground scheme. To do this, you will need to isolate both G terminals. Anything grounded to the G terminals EXCEPT THE BLACK WIRE TO THE OUTPUT TRANSFORMER must be grounded elsewhere. You’ll probably find a terminal strip very near the G terminal you can use as a ground point. You’ll probably also find the G terminal is grounded to this same point. That connection must be removed, it’s usually just a piece of bare wire soldered between the terminal strip ground lug and the G terminal. The new G terminal ground will be at the power supply ground, either the bus bar (if you installed one), or the ground lug on the new C16 cap. Route the supplied 18 ga. brown wires carefully through the chassis, through the electrolytic bracket, and solder it in place both at the G terminal and the bus bar or ground lug."
After a third check of the schematic and checking off each connection point, I rotated all of the bias pots to their lowest setting, plugged into a switched outlet in case I had to turn power off quickly, and powered it up. A quick check of the grid voltages on pin 5 of the power tubes showed between -45 and -46 or so, with one on the low side around -43. I biased the tubes and watched for about 5 mins. No redplating, no issues, and most importantly, no smoke!
I adjusted the bias again after about another 6 or 8 minutes - it had drifted up a bit. I'll run it for longer tomorrow, re-adjust the bias as necessary. I want to run the tubes with a bit lower current - around 80ma - bias can be directly measured at pin 8, correct?
I am jealous of your record cabinet!
My back pops every time I have to move it, and I'm only 31. I can't imagine how it must feel to some of the older guys. Its not just heavy, its AWKWARD. That stack of brown painted lead bricks on the back just makes it an utter pain. I try to avoid moving mine at all costs, I've even brought the solder iron to it. LOL
