doug s.
this solution would likely work, but it's not for me, for two reasons. 1) i am a tuna freak, which means separates is necessary. the tuna in the gtp series' won't cut it for me. i had a gft-1a - easily adcom's best tuna offering - and it is only so-so, unless modded. if yure not into fm like i am, a gtp's internal tuna may be enuff, tho. 2), once i had heard what a nice tube preamp can do for a rig, for me, there's no turning back.rwortman said:I still say your first move is to get a decent cartridge. After that if you want to do separates I would look for an Adcom GTP series tuner/preamp and a power amplifier. This way you get all of your receiver functions without having to purchase a tuner or phono preamp. I ran a GTP400 and GFA535 for years with good results and when I bought it, it clearly kicked the pants off any receiver I had heard (and unlike the audio purist stuff it had useful tone controls and a loudness contour switch. You can probably get both on Ebay for less than $400. Maybe less than $300.
so, i'd use the sx650's tuna & fono stages into the amp/pre combo, until i could afford to upgrade these. (cracker has a rotel tuna he's considering selling; depending on model, it may be worth keeping.) but, i also agree a cartridge upgrade should be in the mix sometime...
as always, ymmv,
doug s.
