Formeruser1
CERWIN VEGA A-2200 POWER AMPLIFIERS SPECS.
SPECS. A-2200 AMP
YEAR 1977
POWER OUTPUT 200 Watts rms per ch/8 ohms
375 Watts rms per ch/ 4 ohms
THD 0.15% or less
HUM & NOISE 100dB
INPUT IMP. 10K ohms nominal
POWER REQ. 120/240 VAC 50-60Hz, 900 watt at rated power
DIMENSIONS 19Wx8Hx11.5D
WEIGHT 35 lbs
CERWIN VEGA 380 SE SPECS.
DESCRIPTION: 15” 3-Way Loudspeaker
FREQ. RESPONSE: 25Hz –20kHz
POWER HANDLING: 5/405 Watt RMS (Min/Max)
SENSITIVITY: 102 dB (1 Watt @ 1 Meter)
IMPEDANCE: 4 Ohms
LF DRIVER: 15” die-cast frame / 2” voice-coil
MF DRIVER: (2) 7” Cone
HF DRIVER: 1” voice-coil horn tweeter
CROSSOVER POINTS: 250 Hz/3500 Hz
PROTECTION: System Fuse/2.5 Amp Slow-Blow 3 AG fuse
HF Driver Self-resetting PTC
MSRP: $540 ea
CIRCA: 1985 – 1991
CERWIN VEGA AT 15 SPECS.
Description: 15" 3-Way
Frequency Response: 28Hz-28kHz
Power Handling Capacity, Minimum/Maximum: 5/400 Watts
Sensitivity, 1W at 1M: 102dB
Nominal Impedence: 4 OHMS
Distortion, Midband at 96dB/M, THD & IM: 0.4%
Maximum Output Level,Pair at 3M,Full Power: 127dB
LF Driver VC Size: 2.05"
Low Frequency Driver: 15" Cast Aluminum Frame
Mid Frequency Driver: (2) 5" Cones
High Frequency Driver: 1" Microcell Polymer Dome with Acoustic Transformer
Crossover Frequencies: 400Hz/3000Hz
Connections: Banana Plugs
Protection: Self-Resetting Circuit Breaker for Tweeter, Overall Fuse
Level Controls: Tweeter,Midrange
Enclosure Type: Bass Reflex
Enclosure Construction: 3/4" Particle Board,Braced
Finish: Scuff Resistant Woodgrain Vinyl
Dimensions H x W x D: 36.5" x 19" x 18.5"
Gross Weight: 90lbs.
CERWIN VEGA CLS 15S
* Frequency Response: 25 Hz – 150 kHz
* 400 watts Peak Power Output
* 200 watts RMS/continuous
* 15" Cast Frame High Excursion Woofer
* Continuously Variable Crossover From 40-150 Hz
* Adjustable Level Control
* Speaker Level & Line Level Inputs
* LFE Input
* Auto-On Sensing
* User Selected Polarity Switch
* Hi Current, Class AB Amplifier Design
* Elegant Black-Ash Enclosure
* Bass Reflex Design
SPECS. A-2200 AMP
YEAR 1977
THD 0.15% or less
HUM & NOISE 100dB
WEIGHT 35 lbs
IMPEDANCE: 4 Ohms
MSRP: $540 ea
CIRCA: 1985 – 1991
CERWIN VEGA CLS 15S
* LFE Input
* Auto-On Sensing
