aussiedan
Ambition beyond ability
Hello everyone. My name is Danny. I am new here. I am trying to find some info on repairing my CT F2121 deck. I am having trouble with the unit not recording properly if at all. It will not show any signal on UV meter until you turn input level up, then you get is a squeel and needle max's out.
I believe its about 1976 vintage. I have issuses with the rubbers- all need replacing, including transport tyres but I dont want to bother with this until I have this recording problem solved.
I was told that the 2 long switches that control the recording function is responsible for 90% of problems. With this unit, there is one very long switch. I cleaned switch with crc brand "CO contact cleaner". I thought it might still be leaving a residue. I rang local audio tech shop and asked for somthing better. Bloke there said they have been using that cleaner with good results for 20 years.
I'm not sure if I'm trying to fix the wrong thing. I only have a basic knowedge of electronics and basic repair equipment (no scopes, etc). I have found a shop that stocks crc "NP contact cleaner" for electronics but it costs heaps.
I would like to hear from anyone that can give me a suggestion or solution thanks...
Sorry I got you into strife with him. What sort of gear do you have? Whats the weather like where you are? Bloody freezing here.
