my current system- just the beginning
Max Flower
Member
I'm ambitious to spritz up my system soon... I have a few projects waiting in the mix. But for now, I've been enjoying this setup for a while. I'm currently setup in small room and usually play music at lower to medium levels so It sounds okay for now.
My current system: Audio Technica ATLP120 USB TT > Onkyo HT-R391 Receiver > Jamo Cornet 20 IV bookshelves and Onkyo SKW391 sub.
The Onkyo stuff is from an entry level home theatre pack from 2012-13. I don't regret getting it as a simple starting point.. It sounded clear and strong to me at the time. After getting more familiar with the sound I am starting to see where it could be improved.
Would I be correct to assume my TT is probably the best peice in this system? All the projects I have in mind to upgrade are to do with speakers/amp/cd player.
I have plans to upgrade the turntable but I can't see myself replacing it for a while. I've always figured if I were to bypass its internal preamp and upgrade its cartridge that I should be set for a while before upgrading other components reveals its weaknessess.
You have to start from somewhere. The Audio Technica table is a good one, because you don't fall into my problem of having to constantly chase a better preamp to get things better. The biggest problem in upgrading the turntable is that you will either need a preamp in my case to use with a vintage Technics SL-D2 or a more expensive turntable again which starts going up by twice in price to get something better than what you have now. Onkyo make good hardware. It's a premium brand above the mainstays such as Sony even if most people wont recognise it at first, I use an Onkyo receiver also it's a good base to build from and it has plenty of power so you can keep it and not worry about a receiver upgrade any time soon.
