GPJeff
I'm confused.
Does this mean the wand does not touch or 'scrub' the record?
Typical for almost all RCMs, you scrub the record with a record brush or pad with the cleaning solution(s). The wand's only purpose is to pull off the solution & dirt from the record. The slot in the wand is the inlet for the suction side of the vacuum. You rotate the platter, turn the vacuum on and in 2-3 LP rotations almost all of the solution is sucked off the record.
