This thread will document my repairs to the PAT5 Pre-amplifier as a spinoff of my other AMP thread http://audiokarma.org/forums/index.php?threads/st70-7199-6gh8a-amplitude-vs-frequency.694384/
This is my solid state preamp for the ST70. Which naturally, doesn't work correctly.
My other is the PAS 3, one factory and one custom MOD
The PAT5 exhibited a moderately loud white noise from both channels on all inputs with volume all the way off. I first checked the power supply.
After removing the PS unit PC32, i removed and tested all electrolytic. Looks like this board has been a lot of heat.
The 220uf were reconditioned on the IM-11 and are down to 5uA at 100VDC. Nothing amazing but acceptible. The 2 100uf's were trashed, so I replaced them. The 1uf was tested good, but I replaced it anyway
The diodes and 1 resistor tested good, shown below are also the two broken 100uf16V caps
The Heathkit was used for testing and reconditioning pf the 220uf as well as the replacement caps
Board re-assembled after repairs
Another shot
Back in the Unit... I did some quick measurements, have a feeling something is pulling down the 42.5VDC rail more than it should so I will have to look at the PC 33 cards and test their components.
Another shot
