David_NC
My Dynaco ST-70 has ruined my other amps... at least in terms of my listening enjoyment. I've used a QSC USA 900 and later a Parasound HCA-1000A as my main amps with a pair of ADS M12 towers. I've enjoyed these speakers, and the rest of my setup, quite a bit.
Recently, I put my refurbed ST-70 in the mix in place of the Parasound. It was good, and I really liked the sound of it. After getting comfortable with it, I swapped the original tubes back in - Tung-Sol 7199's, Dynaco 5AR4, and Sylvania / Philips 6CA7's. I've listened to that combo for a couple weeks now, but a few days ago, I decided to go back to the Parasound due to the fact that it's a pain to use the Dynaco; it won't physically fit into my setup properly. That lasted for two days; the qualities that had really impressed me were gone. Many / most of the tracks I played were lacking something, and, in many cases, sounded sort of lifeless... not bad, but not as lively. Dynaco to the rescue! I swapped the Dynaco back in, and all is well.
Honestly, I did not think this combo of speakers and 35 watt amp would sound so good. The M12's are power whores at 87dB efficiency and really shine with lots of power. The previous amps I used with them are rated at 440 and 200 WPC at the M12's 4 Ohms. My current listening setup has me positioned closer to them than is typical for speakers their size, but I can't change that at present. The worst I can see is that I'd need more power for them in a larger room, though crossing them over at 55Hz to a powered sub undoubtedly helps with that. Still, at this point in time, in this situation, the ST-70 and M12's are a great combo. I'm curious if others have tried any of the larger ADS models, in particular the towers, with a mid-powered tube amp like the ST-70 and what experiences they had.
