juptonstone
Member at Large...
I bought a Dual 1218 which arrived here two days ago. It came complete with the original box, manual, plinth, etc. BUT the motor was grinding and no amount of lube and cleaning helped...
This is where my Dual 1019 motor comes in. Yep! You got it! The 1019 motor bolts right in. A dab of solder to connect the wired to the original clips and I was off! It actually is a plug and play solution. And because the platter is about 3 lbs. lighter, the motor might even give linger service...
The one issue which was present before I changed motors, is 60 cycle hum. I have done everything I can to fix or re ground everything! But it has only slightly improved. So I want to rewire the tonearm using a 4 wire directly connected to the interconnect on the back, and to the cartridge on the front.
Does anyone have thoughts, comments or suggestions that might help? Has anyone retired a 1218 tonearm?
