Pol
Thank you for your the detailed and informative answer! ..it's very appreciated!!They are the same part. The TU at the end denotes the original packaging, and I believe it is short for "tube"
Q2 2SC1212A(C) replaced with KSC2690A
jajajaa.. yes, in my city there's only no more to five electronic parts shop and nobody can't help me; I live in Barcelona - Catalonia (Spain). Unfortunately this is not America; if someone can help me will be very appreciated. Now I have all parts but I'm missing KSC2690A and the ESRs. Do you know if this is the transistor I'm looking for?Tell us where you live - you seem to be searching for stuff all over the planet
I'm looking for KSC2690 but your link say KSC2690AYS ..is it the same transitor?
Concerning DIGI-KEY I have bought this diode in order to remplace Zener diode YZ-140:
https://www.digikey.es/product-detail/en/on-semiconductor/1N5244B/1N5244B-ND/977602?cur=EUR&lang=en
Do you can tell me if I made a correct purchase?
GREAT !!! THANKS !!!Yes
Yes
We like 9100s.
About the only thing I'll add is that it's generally a good idea to use low ESR (equivalent series resistance) caps in power supplies. Your main filter caps are fine, but you chose Nichicon FG for the PS board. Why use low ESR? Series resistance at the input creates high frequency noise across the cap, and at the output, it can actually cause more ripple. Series resistance can also affect transients. Let's say you're watching a movie, you've got the amp cranked up and suddenly, there's an explosion!...an instantaneous large demand is placed on your power supply, to send the necessary current to your amplifier stage so it can reproduce that explosion with authority and as distortion-free as possible. While that may be a gross example, it illustrates why increased ESR to rapidly changing current demands can affect performance.
Here's an informative video showing various type caps in a circuit, demonstrating the differences in signal integrity due to ESR differences:Having said all that, the amp will work fine the way it is.Good job, Andrew.
Now for some ESR meter results on some of those old ELNA low leakage caps from the control boards.
10uf 25 volt low leak cap: ESR 7.6 ohms about 5.3 appears to be more acceptable
1uf 50 volt low leak cap: ESR 18 ohms! This rating doesn't come up on my meters chart but appears to be way too high.
10uf 25 volt low leak cap: ESR 6.5 ohms about 5.3 appears to be more acceptable
1uf 50 volt low leak cap: ESR 15 ohms again appears to be another very high reading but not on my chart for this value.
Bigger values all appear to have "mostly" tested really well:
220uf 35 volt standard cap: ESR .31 ohms about .17ohms appears to be acceptable
100uf 35 volt standard cap: ESR .35 ohms about .32 appears to be acceptable
470uf 50 volt standard cap: ESR .10 ohms about .09 appears to be acceptable
47uf 35 volt standard cap: ESR 1.8 OHMS about .68 appears to be acceptable (yes this one a little off)
100uf 35 volt standard cap: ESR .32 ohms about .32 appears to be acceptable (on the money)
220uf 10 volt standard cap: ESR .29 ohms about .6 appears to be acceptable.
This is only a few capacitors and obviously, it's a real mixed bag of results. Some test really well so one would wonder why would you want to change any, some are questionable but then others just tested horribly! Either way, the results are amazing and I'm so glad I finally got around to doing this.
Hello and hi. First time on the forums. Recapping my owned since new ka-9100. Love the beast, great sound but its time. Noticed an oddity on the eq amp board 1410 u/4. C108 wasn't joined properly as per diagram or should I say the leg that ties to the resistor wasn't even soldered. Odd that it still worked all these years. Anyone that has recapped their 9100 noticed this?Hi,
First of all I'm sorry for my english. A friend is restoring my Kenwood 9100; just a question..
Do you can say me what type of tune caps I must to buy from the shop of below; (A or B)?
A..
https://www.hificollective.co.uk/catalog/nkg360-15000uf-nichicon-type-gold-tune-p-6333.html
B..
https://www.hificollective.co.uk/catalog/nkg380-15000uf-nichicon-type-super-through-p-6334.html
We'll keep in touch,
Of the two listed, use A. It has the correct dimensions and the correct lug spacing and offset, and is a direct replacement. It is also expensive.
B won't fit the clamps - don't use.
This is a much less expensive alternative but requires some creativity to adapt, as the solder lugs are too close together and aren't offset as required to be a direct replacement..
