ClayTune
Well-Known Member
The "natural sound" R-3.Looks like you made a great choice....
What model of Yamaha receiver did you pick ?
I see one at Monoprice that is 60 watts total power.I constantly see inexpensive subs at my Goodwill store, you might find one near you as well.
That won't matter. The sub's own built in amp will power the sub and will only use the power from the Yamaha as signal and the adjusted crossover in the sub amp will send the power from the Yamaha onto your bookshelf speakers minus what it filtered out so both sub and bookshelf won't be producing the same frequencies. Not explaining this very well, maybe someone with more knowledge on exactly how this works with an amp without a sub out.When I buy a Subwoofer should its wattage be equal or greater to that of the receiver?
Would this be compatible with my Yamaha Natural sound R-3 Receiver if the receiver is rated at 35 watts per channel?
Does that mean it can power a 60 watt Sub because 35+35=70 total Watts?
The speakers I have chosen are 100 watts.The Yamaha won't "power" the sub exactly but simply provide a source. The Yamaha volume control will still be your primary point of adjustment but the sub would usually have at least a couple of controls on it. One is for the crossover point which is where it "takes over" from the smaller speakers at (for example 100 hz) the low frequencies to send that signal to it's larger woofer. Above that point is handled by the smaller speakers with perhaps some overlap. The other control will be for volume of the subwoofer and you set it so that it does not overpower but compliments the range of the little speakers.
That will probably work just fine with the speakers you chose. Please read the Monoprice blurb on the S/W as it does a fine job of explaining what it does and how to adjust it.
The 100 watt rating on those speakers can be misinterpreted. You will likely never come close to driving them with 100 watts, and they don't "have far more power" than the receiver, they can accept more power. However the receiver can also probably put out more power than 35 but at unacceptable levels of distortion.
Most "normal" listening is actually down at quite low wattage levels, perhaps 5 watts plus or minus. Having more power available is great but with a system such as you are putting together it will rarely come into play.
You're correct. I am trying to talk myself into it based on a few audiophile recommendations here.Wait. Get the system set up and just listen for a while.
I'm not trying to talk you into it, you are. I do not use a subwoofer in my stereo system and you might not want it or need it either.
Get the owners manual for the R3 here: http://www.hifiengine.com/manual_library/yamaha/r-3.shtml
It says a bit about the Loudness and Bass Extension controls.
I guess I was looking to understand why the bass extension would be inadequate and why the Subwoofer would be a definite must have.
I listen to all sorts of music.
So, what situations would the subwoofer be necessary that a bass extension knob would play an inadequate role in?
Like Monty said - enjoy/get your new system setup and start listening. Only you can decide if it needs more bass not us. If you fell to earth - and listened to the system for the first time - you would probably think it sounds wonderful - so stay that way and enjoy it - if you happen to have a frame of reference - and listen to the system and think it needs more umph - then in the future you might want to get a sub. Only you can figure this out.
Interestingly, I am not a big "bass" guy.
I like some bass but I honestly lack an understanding or proper comprehension for the fetishization of bass.
As a musician I do enjoy the instrument and sound of it of course. But with my most recent set up (built from mostly used parts) I had these vintage KLH speakers that were way too bassy and seemed to drown out the subtle beauty of everything else.
I am not in any rush, so I will definitely give the system a listen prior to adding a Sub. In the meantime I find it helpful to learn how to connect things just in case.
Well the new ones I ordered (and I emphasize the word 'new') seem to have a decent balance according to amazon reviews. They're called "sound appeal 2.0" speakers.It's good that you have the KLHs - that will be your frame of reference to help determine what you want from the new speakers.
I actually have those speakers. They sound very good especially for the amount they cost. Very clean highs and warm mids, and a surprising amount of base for their size. I actually bough them to gut the components for another project. But they sounded so good they are now the main speakers on my second system.
picture of when i had them on my main system for testing.
