My new TEAC A-1250 S - Dirtiest machine ever! (RESTORED PICS)
One other thing to watch out for on that machine is the forward / reverse control lever switch. The contacts on that switch are kind of delicate and a they are a major PITA when they start going bad so it’s best not to use it unnecessarily. Use the buttons to starts and stop the machine and use that lever to select the direction only rather than shifting the lever when the machine is rolling, it’ll help prolong the life of the switch.
+1
Never use the lever while the tape is in operation. If you do so you also risk tape damage because the circuitry is not designed to maintain correct brake operation when switching modes. Set mode then operate.
Also, only change the tape speed switch when powered off or, more practically, when the right hand tape shut-off sensor is down. This shuts off the capstan motor and avoids a damaging spark inside the tape speed switch. Over time this will cause damage.
Classic machine you have there, very worthy of continued service. It is an early version of the well regarded 1970's series Teac reel to reel machines. Watch some Youtube videos and take your time cleaning the old lubrication out.
