raymondjiii
I've been wanting to do this for a while: Hook up all of these tuners and test them out. I wanted to tune into the same stations and most importantly - not have to completely disconnect things and then forget how it sounded. Here, I could easily switch between all units.
The main issue is that I don't know exactly what the quality of these tuners was (or is) when I received them.
They are all using the same FM antenna through the Channel Plus distribution panel shown above.
All RG6 connections are compression connections on both ends.
All RCA audio connections go through a switch box. I know....but this one feels solid - all metal - solid turning switch (no plastic or push buttons). Not sure of the model but it's from Newark.
Tried to keep the RCA output cables of the same brand and length but a couple are different.
All units plugged into the same Belkin 10 outlet all metal adapter.
I did not test any AM functionality.
On the stack is:
1) Sony XDR-F1HD
2) Yamaha TX-950
3) Kenwood KT-5020
4) Kenwood KT-951
5) Marantz ST-74
6) Yamaha TX-350
7) Carver TX-11a
Best Reception: Sony XDR-F1HD (second place not even close but I'd give it to the Marantz ST-74 or the Carver TX-11a)
Best Sound: Carver TX-11a (second place not even close but I'd give it to the Marantz ST-74)
I talked about the Marantz ST-74 in the past and now that it's connected to this antenna it is very good. Fmtunerinfo.com says that this unit is a mystery, very rare for some reason. I cannot find any information about this model at all.
All connections are RG6 Quad. 3 of the units needed a 75 to 300 ohm converter since they only take a 300 ohm FM connection. I'm using RCA branded 75/300 ohm adapters (purchased through solidsignal.com), I used these units for the name-brand vs something terrible from amazon. However, the units that are using the 75/300 adapters are by far the worst on reception, not sure why. I can play with them more. I had to cut the ends off two of the the 75/300 adapters and strip the ends to bare copper - this is the how the connection is on the tuner. The unit that has screw terminals for the 300 ohm connector seemed ever so slightly corroded but too minimal to make a difference (I think).
I didn't include my Adcom GTP-500 II preamp, I would rate that one about at the halfway mark, but again there were no real second places in this test.
I do like the units that have the wide/narrow option but having on narrow was best.
I also like the units that let you "fine tune" (smaller steps on the tuner), but did not server any point in my reception tests, did not get me any station that I could not already get on the Sony XDR-F1HD.
I have two more Yamaha tuner units to test but I did not have any more of the 75 ohm push connectors. The Yamaha TX-950 on the stack uses a push on FM connector and has an A/B switch for the antennas.
The Carver TX-11a has 2 option buttons at the bottom (can't see at the moment) but I suspect those are what gives this unit its exception sound.
