My recently aquired Technics 1210MK5
DonBattles
Well-Known Member
I've had this for a few weeks now and finally understand the draw and passion of analog. The table is pretty much as I received it with the exception of the TT Weight. I did paint the cover on the outboard power supply as it simply stood out too much with my other gear. Below are some pictures of the current set up.
Power supply before
After
Cool. I do dig the cart, though. An Ortofon? Which model/stylus, and do you like it? Love the full range speakers, too. I have the Madisound model...perfect for Sinatra!
The cartridge is a KAB/ Stanton Groovemaster II AE Integrated Cartridge with nude Stereohedron stylus. As for me liking it I cannot really say as I've nothing else to compare it to. I do have the original Technics head shell and am currently looking for a MM cartridge. Currently considering the Shelter 201, Sumiko Pearl, or the Goldring G2100. I will say the sound I get from this set-up is at least as good as the sound from my MCD201. It's has about the same amount of detail and a bit more laid back than the digital source. All in all I enjoy both and will be looking to improve the Technics a little at a time. I am considering the tonearm rewire or maybe even a tonearm change. Isolation platform or feet, platter bearing upgrade, and maybe dampening the platter itself using either Dynamat or modeling clay (if it's a good idea?). So needless to say more to come :D
The cartridge is a KAB/ Stanton Groovemaster II AE Integrated Cartridge with nude Stereohedron stylus. As for me liking it I cannot really say as I've nothing else to compare it to. I do have the original Technics head shell and am currently looking for a MM cartridge...
What's your cartridge budget?
...maybe dampening the platter itself using either Dynamat or modeling clay (if it's a good idea?)...
Not really- you could throw the platter off. I do, however, suggest adding a heavier mat- I have a copper TTWeights mat on my Technics SP25, and they also sell an alloy version. Dave Cowley across the pond sells a nice machined one, or you may get lucky and find a good deal on a vintage SAEC model.
The bearing upgrade will give you mild but noticeable improvement. The arm may already have a re-wire, being modded by KAB. I like the M5G RCA cables and the KAB turret board plate.
Best of luck with it!
