I have actually learned quite a bit since I have been here. Now I am not too afraid to pick up a soldering iron and go to work with it.
The funny thing is that I bought a cheap Chinese soldering iron a few years back for about $10. And frankly the damn thing works great. I have already used it on a couple of different amps. Never let me down...
So today I finally decided to take the cover off of my garage door opener that has being only working intermittently. All signs pointed to it being an issue with the logic board and possibly a bad solder joint at that. It would start moving and then just shut down. The light would turn off and then nothing. If you smacked it the light would come on and it would work again. Also sometimes the light was sort of blinking while it was going up or down and it was not supposed to do that.
So at first I thought it might just be a bad wire connection underneath a wire nut. Retwisted that and it seemed to be working but then it started acting up again. So its time to take a look at the logic board. I had the cover off and was running it up and down when the problem surfaced again. Touched the connector to the logic board and the light came back on. OK, I now know the general area of the problem... Used the good old "tap it with a chopstick" method that I learned here on the back of the board. And sure enough when I got to the last solder joint I saw a change. Managed to get the board out, reflowed the solder on all solder joints for the connector and added a bit of fresh solder. Now it is working again and doing great. If I would have called someone to come out and look at it they may have charged me $125 and recommended a new logic board. But the problem is that they don't make parts for this 30 year old opener anymore. So there is no guarantee that they would have actually fixed it and not just recommended installing a new unit for $600...
Cheap fix with the skills I learned here and my $10 Chinese soldering iron. That thing has paid for itself over and over again.
