PakProtector
AK member
*bricktop puts car in classifieds*
must be a very nice car...
cheers,
Douglas
Please put up schematics of what you've done. I am sitting by with great anticipation.
Will do Douglas, I'm do some doodling soon. I will tell you that I tested the 6CL6 long-tail pair with BJT CCS and achieved an output swing of about 150Vpp with less than 0.5% THD (my measurement limit). Single ended gain at the particular screen voltage, which I forget what it was, was 35 v/v. My one concern with this is if it will have enough gain to make the required input signal reasonable, but i do have an aikido preamp in the works which has plenty of excess gain. I did a little simulation before and I think i determined I needed about 15 volts peak input per grid for full power out. The EL34s are biased at -25v (about 25ma/tube), but don't need to be driven full to 0v for full output. So I THINK i'll have some excess gain for feedback, which the transformers have a dedicated winding for, which is sweet.
Little bit of wiring here, lead dress for the transformers, which will make it easier in the long run. Extra 70v winding too if I ever want to try cathode feedback. We'll see.
That buss is one thing I'll be paying close attention to. Am I right in thinking that you will keep the higher current devices down by the first cap and the signal stuff clear to the other end? BTW, a close up of the grounding would be cool.![]()
She's making music!!
Here's a pic from late in the game. Solid state CCS board is in and caps tie-wrapped to ground bar.
Can't turn it up real loud tonight (neighbors), but will give better listening test tomorrow:thmbsp:
hey-Hey!!!,
Consider adding a cap between your cathode node and the wiper of your screen balance pot. Maybe two, one to each screen from the cathode.
cheers,
Douglas
addition: Also did brief power test to see where crossover distortion was noticed = at about 25 watts.
and also, hum and noise with grounded input was below 8mV.
Not bad! You might never make it to 25W with your present speakers![]()
So have you applied any feedback yet? Any square wave attempts?
I'm excited; this amp went from Douglas' garage, to my basement, to "great success".
Those numbers were with feedback, no square waves yet, I shoulda done that while i had it hooked up, but I forgot.
Listening to it now, it does have bass like no other tube amp I have. VERY clear too.:thmbsp:
