Goodmans made really nice drivers. Glad the purchase worked out for you. I passed on a pair of these because I didn't have the space. I have too many speakers, as it is.
The issue here is that the EE line followed the Goodmans practice of omitting inductors for the woofer and midrange as a cost-savings measure. The EE line was less expensive than some of the earlier units so this makes sense. With a small amount of expense you can make a kick-ass speaker.
You didn't include a crossover diagram, but the two values you listed suggest a crossover of:
5 uF = 3,979 Hz. Call it 4,000 Hz. So midrange runs 4k Hz to infinity.
2 uF = 9,947 Hz. Call it 10,000 Hz. SO tweeter runs 10k Hz toi infinity.
So it's a two-way with a tweeter for the high-end?
You might consider a few modifications:
(1)
Adding inductors to the midrange and woofer. The problem is the midrange and woofer will overlap and create all sorts of mess. The woofer should be limited with an inductor to remove the overlap with the midrange. Instead of relying on the mechanical limit, the woofer driver will have lower distortion with an inductor. The woofer is mechanically limited, of course, but it still has distortion out of band since it lacks any annular rings the way a coaxial (woofer plus tweeter) normally has. The midrange's surround could have (but unlikely) been tinkered with to reduce the low end but unlikely. This is just a cost-savings measure which should be fixed.
(2)
Add bypass capacitors. Adding (0.1 uF and 0.01 uF) to each capacitor improves its performance. Speeds up response time with higher frequencies.
(3)
Add the flowerpot to the midrange. This prevents cross-modulation, which will be a big issue since the midrange back is not sealed. I've elsewhere explained for the Bozak.
(4)
Add Bozak cotton batting and a hanging curtain. Since these are infinite baffle, the more backwave you can absorb the better and cleaner your bass will be. So I think adding the hanging curtain will be a dramatic improvement. So will replacing the fiberglass with thick cotton batting.
