AHH! Bingo! Thank you!! Now, to track down a dustcover...I believe that is a Pioneer PL-7 idler drive from the mid-60s.
PS. This would've been it's original cabinet it was fitted in, see the ugliness ?
Old style classy... very nice. Loved reading about it, good job IMF.Actually, I think that is quite handsome.
The bearing pad is actually smaller than the PL-41 surprisingly. Here is my PL-7 with the original casing.That's an idler table that I would like to own. Rebuilt I bet it would sound great.
Pull the main bearing, I'm betting that it uses the same bearing pad as a PL-41 and it's probably bad at this point. You also want to clean and lube the bearings in the motor and see if one of the idler tire guys can recondition the idler wheel.
That table is in pretty good shape, it's worth the trouble of a full rebuild.
BillWojo
It appears the sides and cover are one hinged unit, making cartridge alignment a little easier.I think it's beautiful! Makes aligning a cartridge a bit of a pain.
