McGlentosh
proud McOwner since 1978
I've read so much info and advice regarding which taps to use when connecting B&W N802's, in this and other forums, that my head was spinning, so I e-mailed B&W to get their recommendation, as follows:
"I am powering, via bi-wiring, my N802's with a McIntosh MC352 amp. The
speaker manual says the 802's impedance is 8 ohms nominal (3.5 ohms
minimal). McIntosh recommends attaching the 802's to the 4 ohm taps on the
amp. What do you recommend, and why?"
And this was their reply:
"Thank you for purchasing B&W! We specify the Nautilus 802s as a nominal 8
ohm impedance loudspeaker, and do recommend that you connect the speakers to the 8 ohm taps for best performance. In the past, consumers with this same scenario have advised upon listening to the speakers using both taps, that the 8 ohm taps do perform better with their N802s.
Best Regards,
Michael Sheehan
B&W / Rotel
Comments?
Best Regards,
Michael Sheehan
B&W / Rotel
Comments?
