nicst
The stock RIAA low-end cut-off capacitors were 2200µF/6.3V and these were replaced with Nichicon PW capacitors of the same capacity but with a higher voltage rating (16V). Whenever possible, it is best to avoid low voltage (e.g., 6.3V and 10V) rated capacitors as their performance and longevity are typically poorer than their higher voltage counterparts. I usually try to use capacitors rated at a minimum of 25V, but in this case there wasn't sufficient space on the board.
Hi again! I am copying your mods to my NAD 1000, which is very similar. I took your advice to replace the DC filtering/decoupling capacitors C205/C206 from 220µF/25V with 470µF/35V United Chemicon KZE. But in the NAD 1000 the C215/216 are 1000µF/35V (strangely, since both the wiring diagram and parts list say 6,3V). I have a pair of 1000µF/25V Nichicon PW in store that would fit. But in the NAD 106 you say they are 2200µF. Should I increase to 2200µF or do you think 1000µF is a better value for the NAD 1000?
